Do the commands listed in that post track both ingress and egress traffic on all interfaces?
What about switched interfaces? Do I need to configure those manually?
I have all of the commands needed to setup ingress and egress on a 6509. I will post them tomorrow when i get back to the office.
but to answer your question, I had to manually configure every port that i wanted to monitor. I ended up just setting up Ingress and egress on the vlan instead.
Thats interesting. I posted this same question on cisco's netpro forum and was told by two different people that there was not a way to monitor layer2 interfaces, only layer3. I thought I saw somewhere that there was a way to do layer2.
Are you setting up ingress/egress on layer3 vlan interfaces? I found that does work.
Here is a link to a Cisco document that goes through the steps for configuring Netflow on 6500 series swtches, both hybrid and native IOS. They key command to monitor layer 2 is "ip flow ingress layer2-switched vlan xxxx". Also verify the NDE version is version 5, by default version 7 is configured.
www.cisco.com/.../netflow-catalyst6500.pdf
Hope this helps
Use the code below to monitor a vlan. But you could also replace interface Vlan??? with interface GigabitEthernet1/41 or any other port that you want to monitor.
ip flow-cache timeout active 1!mls aging fast time 8 threshold 127mls aging normal 32mls flow ip fullno mls flow ipv6mls nde sender version 7!interface Vlan??? description **???** ip address ???.???.???.??? ???.???.???.??? ip pim sparse-dense-mode ip route-cache flow ip igmp snooping mrouter interface GigabitEthernet1/48!interface Vlan??? description **???** ip address ???.???.???.??? ???.???.???.??? ip pim sparse-dense-mode ip route-cache flow mls netflow sampling!interface Vlan??? description **???** ip address ???.???.???.??? ???.???.???.??? ip helper-address ???.???.???.??? ip flow ingress ip pim sparse-dense-mode ip route-cache flow mls netflow sampling!ip flow-export source Vlan???ip flow-export destination ???.???.???.???!end
One other thing to keep in mind when trying to monitor layer 2 interfaces for NetFlow on 6500s. In order to get both routed and bridged traffic from Netflow, you'll need either a PFC3B or PFC3BXL running IOS 12.2(18) SXE or later. If you have a PFC3A or you're running IOS code earlier than 12.2(18)SXE, you'll only get routed traffic stats.
good catch. I forgot to put that in there.
Thanks. After having spent a stupid amount of time trying to find out why I couldn't get layer 2 traffic from a 6509 with a PFC3A card, I figured I'd try to save someone else from the same waste of time!
