Our Orion database is too large can anyone suggest a way to control the size? Our NetPefMon database is 50+GB consistently.
SQL Server 2005 Enterprise / Orion 9.1 SP4
290 Nodes / 483 Interfaces /
130 Netflow Interfaces
What are the largest tables in the DB?
Netflowsummary2
There was a previous issue regarding the grooming of that table. Which version of NTA do you own?
There are some truncating steps you could attempt in some of these posts below as a workaround or considering upgrading your version of NTA.
http://thwack.com/search/SearchResults.aspx?q=Netflowsummary2&o=Relevance&PageIndex=1
NTA Version 3.1
At this point I would suggest opening a Support ticket.
