Is there a way to get the specific OIDs that are currently being polled from ORION?
You may find the information you need in the following articles in our Knowledge Base:
This is variable depending on the type of device. Do you have a specific device you are curious about?
Linux Redhat and Windows 2003. We only have Orion configured to use the out of the box monitoring due to information assurance reasons. I am wondering if there is a configuration file that I can access that provides me the specific OIDs of the metrics that Orion is polling. Thanks.
How come I don't get anything (OID not supported) when I use the UCD MIB to pull disk IO stats from our Windows 2003 server? Does that mean that windows does not support disk IO stats? Thanks.
UCD is for Linux systems and is not supported by Windows.
If you want to use SNMP to monitor Windows Disk I/O you will need to use the free SNMP Infomant extensibility agent and some custom pollers. I have posted a thread that outlines how to monitor Windows Disk I/O which you can find HERE. It will walk you through two different ways to accomplish Windows Disk I/O monitoring.
