we are going to install a second NPM along with EOC. We intend to move about 500 nodes including historical data to the new NPM/DB. Is there a procedure for that or has anyone done this before?
Thx
Klaus
Have you looked at this?
To reassign nodes to a different polling engine:1. Click Start > All Programs > SolarWinds Orion > Advanced Features > Orion Service Manager.Note: Confirm that you stop the SolarWinds Network Performance Monitor Service on all polling engines.2. Click Start > All Programs > SolarWinds Orion > Advanced Features > Monitor Polling Engines.3. Click Servers > Poller Load Balancing, and then select the nodes you want to reassign.Note: Use Shift + click to highlight multiple consecutive rows, and use Ctrl + click to highlight multiple non-consecutive rows.4. Click Polling Engines > Move Selected Nodes to *, substituting the target polling engine for *. The node is reassigned, and it reflects the name of the polling engine in the polling engine column.5. Click Start > All Programs > SolarWinds Orion > Advanced Features > Orion Service Manager to restart Orion NPM services.
this is about moving the database to another server.
I want to move selected nodes including historical data...500 out of 2500.
I thought that might only work to move nodes to an additional polling engine feeding into the same database.
Please confirm that this procedure works between 2 standalone NPMs with separate databases only connected by EOC.
I've done this several times - for various reasons. The easiest and safest thing I've come up with is to shut NPM down, copy the DB to a different name (or same name if different machine), then bring it up on the new server. I've found I must do it with nothing connected to the NetPerfMon DB while attempting.This allows you to keep the original DB in tact for fail-back as well, and if your doing an upgrade, you can install the older version of NPM on the app box and point it to the new DB, then upgrade.
So will this will keep all the settlings, the interfaces that are beinb monitored or not monitored? i have about 8000 nodes to move. seeing if this will work./
Christopher, Did this work for you? I am in same situation with NPM v10.4.2. We have two instances of NPM/NCM and need to move about 1/2 of the elements monitored from one to the other. These instances do not see each other, and firewalls cannot be manipulated to allow access between the two. I have copied the DB from the original to the new instance, though I am prompted not to continue unless I am migrating to a new server. I do not want to affect the older NPM's monitoring or performance until I get the newer one configured.
--Does anyone know: if copying the DB to a new SQL svr, then pointing a new instance of NPM at the copied Db and selecting CONTINUE when asked if I am migrating to a new NPM server will have ANY affect on the old NPM server or its monitoring of the elements?
-Thanks
