How to set up Admin Account Authentication? I cant figure it out and I have looked to an easy solutions but can not find it. Thanks
This filter is dependent on the "Admin Accounts" User Defined Group, so your Admin Accounts need to be specified in that group.
What do you mean by "Admin Account"? When a user uses "Run as Admin" in Windows? Logging into the LEM as Admin? Something else?
I want to enable the Admin Account Authentication that is highlighted above. Thanks
Thanks so much for the help. It worked. Do you happen to know if there is e-mail notification for like when accounts get locked out? Thanks again
By default, no, but you could certainly use Rules to create one.
Thanks for info curtisi
