Can NCM backup configs for Cisco VG204's and Cisco VG224's?
Actually, out of the box Cisco. This responds just like any other Cisco switch as far as the command line and backups go. Enable Level = 'no enable login' for our VG devices, but everything else is the same as our production switches.
Do they have a command line interface (even if menu-driven)?
Jiri
The Cisco VG224 does have command line configurations.
Then it should be possible to make NCM back up the config. Try it and if it doesn't work out of the box, you'll have to modify the device template. We can help you with that.
Thanks Jiri. I will give it a shot and if I have an issue I will let you know
Mike
I have been backing up a couple of VG224s and a VG202 for a few years now. I don't think you will have any trouble.
