Hello,
I bet there is already a thread on this but I was wondering if you guys had instructions on how to integrate Scrutenizer with solar winds NPM. Thanks in advance for any help
It was a few years ago but I did that for a client. I found instructions on their site to do it before.
Here is what I found just now. It was pretty simple if I remember right.
http://forums.plixer.com/how-to-integrate-scrutinizer-with-solarwinds-orion-t1695.php
Thanks mdriskell, I will try that out
Hi Mdriskell,
When I try to run the command in the instructions I get the following error message
"Msg 4060, Level 11, State 1, Server MADHFSVNPMTI01\SOLARWINDS_ORION, Line 1Cannot open database "NetPerfMon" requested by the login. The login failed.Msg 18456, Level 14, State 1, Server MADHFSVNPMTI01\SOLARWINDS_ORION, Line 1"
I tried to go into the solar winds configuration wizard but could not figure out which login to use. Any suggestions for this? Thanks again
Hi Mdriskell,When I try to run the command in the instructions I get the following error message "Msg 4060, Level 11, State 1, Server MADHFSVNPMTI01\SOLARWINDS_ORION, Line 1Cannot open database "NetPerfMon" requested by the login. The login failed.Msg 18456, Level 14, State 1, Server MADHFSVNPMTI01\SOLARWINDS_ORION, Line 1" I tried to go into the solar winds configuration wizard but could not figure out which login to use. Any suggestions for this? Thanks again
I just ran the command again and took out the -d NetPerfMon and got the following error.
"Msg 208, Level 16, State 1, Server MADHFSVNPMTI01\SOLARWINDS_ORION, Line 1Invalid object name 'Resources'
Any ideas?
Like I said in my initial reply it has been years so I really don't remember the process nor do I have that product to test with. I found how to integrate the product from Plixers site and there were step by step instructions at the time.
If you are looking for the database login I suggest this thread
Look for Andy Coates reply as he shows you where to find the database user info.
