Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Map Maker
JamesWenger
I would like to be able to click on a link on the map of our network and see everthing we monitor at that site, servers, routers switches, ect. For example, we have 15 differetn site accross the US, and right now when I click on a site it only shows the information of that router, but I would like to be able to click on that site and it will bring up all links to all of their Servers. switches and routers.
Can this be done?
Find more posts tagged with
Accepted answers
All comments
Network_Guru
Yes, the Map Maker is actaully designed to do this. You create multiple maps, each with more details than the previous. Once you have created them all, you nest them, so that you can drill down from a 25,000 ft level right down to 10 ft.
I suggest you read the mapmaker portion of the admin guide, and watch the video tutorial on the web site.
-=Cheers=-
NG
ssharma
Sure, you can do that. You will need to create maps for all the sites individually, and then you can move those maps as clickable links onto a geographical map of the US (which becomes the parent map), just like you move normal network nodes onto a map. It's pretty simple, and works quite well.
~Shshank
http://www.shshank.org
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
