Hi Guys,
I have recently migrated my solarwinds to a new server. However after the migration I am unable to see the Advanced/Basic alerts. What should I do?
Hi, check whether they are not temporary disabled (default option for fresh installation). Just run
- Advanced Alert Manager
- Basic Alert Manager
There's checkbox "Disable all Actions"
Nope. I can't see the advanced alerts or basic alerts that I have created in the listing.
oh, does your box have new name or ip address? Can you see more engines on "Polling Engines" web page?
You can check database whether those alert definitions are still present.
Advance Alerts:
SELECT * FROM AlertDefinitions
Basic Alerts:
SELECT * FROM Alerts
My server has a new name. I can see the defined alerts in the database.
I assume that those alerts are assigned to your old engine which is not valid anymore. I think you should open support ticket (attach diagnostic) and support will help you to correct data in database.
JFYI:
alerts has column [EngineID], this must match to record in table [Engines]
