We always have up to date configuration of all devices in Solarwinds (via daily backup job). I want to run some scripts against some of these configs, but I do not want to download them directly from device. Can I query these configs using SWIS API?
A query like this should work:
SELECT c1.NodeID, c1.DownloadTime, c1.ConfigFROM Cirrus.ConfigArchive c1INNER JOIN ( SELECT c2.NodeID, MAX(c2.DownloadTime) AS DownloadTime FROM Cirrus.ConfigArchive c2 WHERE c2.NodeID IN (SELECT NodeID FROM Cirrus.Nodes WHERE NodeCaption LIKE '%DSW%') GROUP BY NodeID) c3 ON c1.NodeID=c3.NodeID AND c1.DownloadTime=c3.DownloadTime
I referred your question about Cirrus.ConfigArchive vs. NCM.ConfigArchive to the architect for NCM. I suspect the reason for having both of them is historical, but I don't know what it is.
Certainly. You can query the Cirrus.ConfigArchive entity: http://solarwinds.github.io/OrionSDK/schema/Cirrus.ConfigArchive.html
Thanks tdanner. Sorry my question may be misleading. I am aware of the Cirrus.ConfigArchive entity, Perhaps the challenge is just a matter of constructing the SWQL query. I am looking at something like this:
SELECT TOP 1 Config from Cirrus.ConfigArchive C
WHERE C.NodeID IN (SELECT NodeID from Cirrus.Nodes WHERE NodeCaption LIKE '%DSW%')
ORDER BY DownloadTime DESC
But this yields just 1 result whereas the sub query should yield 60 NodeID's and I need the latest config of those 60 nodes.
On a side note, which is the official recommended way to access NCM entities? We have Cirrus.ConfigArchive & NCM.ConfigArchive entity. Is there any difference between two? I can't grasp the logic in which entities are grouped hierarchically. Sometimes I remember the entity name but spend significant time exploring schema to find the parent entity. In the earlier versions, I could grep the offline filenames now it is slightly trickier. Perhaps I should open a different thread to discuss this.
Thanks! Let me try this at work next week.
In terms of differences in tables there is no difference. Cirrus one is old. It left there for compatibility. Suggest to use NCM one
