tweaking polls per sec to support UDT...
doesn't look like existing system accounts for UDT. I have set to recommended polls and still get the below banner
and the link is <not found>.
FYI
looks like restarting the module engine on all of my polling engines did the trick.
thanks
Larry,
What do you have the UDT polling set at? That link will work if you install the local help files. They should have been included within the .zip download.
Jeff
gotcha, I'll install local help files. did not do that.
Polling set at default 30 min.
ok. so that did it for the help files, but polling is still an issue.
I have set the poller intervals to the recommended settings on each engine.
thoughts?
Changing the polling interval in the UDT Settings page sets the global polling interval with is used for all new switches and routers added to UDT after the settings change is made.
Existing switches and router will retain their original polling values.
If you need to change the existing switch and router polling intervals, you can do this via the Port Management page.
Set the 'Show' drop-down to 'Nodes', select the nodes you want to change the polling interval for then click the 'Edit Properties' button. At the bottom of the edit properties page you should see the polling interval fields for UDT. Changing these values will update all devices you have selected.
Regards,
Steve
great workaround.
my point is I have my "polls per second tuning" set to recommended and I'm getting this notice. Is the tuner not set to account for UDT polls yet? is there a rule of thumb to use to account for this?
