I have a question regarding alert actions.
I have an advanced alert that is set to send an email when a node goes down. The action is only taken if the node is down for 3 1/2 minutes to prevent the action being taken on bounces.
On the same alert I have a reset action set to send an email after the node has been back up for 10 minutes.
What I am seeing is that I am getting the reset actions even though the device never met the minimum trigger actions. From what I can tell in the configuration there is no setting to say only execute the reset if the trigger took place.
I have already applied the appropriate hotfix hoping that would take care of the issue. Am I understanding the syntax right will my reset happen regardless of the trigger?
Any help would be appreciated.
