Hello,
We use cirrus to backup our cisco routers and ASA all work fine.
I need to save configs of our motorola WS 5100 but i have 2 problems :
1) i need to type cli before i can enter login/password, so i'd need to know how to add something in login infos before the username
2) if 1 can work a day i'd need to type a different command than to backup cisco config (very similar but some different syntax). Is it possible? if yes how?
My best regards
Michel
