Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Goal Oriented AI
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Missing Poller XML File
mstensta
I just downloaded Orion V8.0.1 demo and it seems to be missing the “PredefinedCustomPollers.xml” file, which appers to be needed to add custom MIBs. How can I get a hold of this file, or is there another way to add custom MIBs? I'm specifically refering to this document:
http://www.solarwinds.net/NetPerfMon/SolarWinds/wwhelp/wwhimpl/common/html/wwhelp.htm?context=SolarWinds&file=OrionAdministratorGuide.1.177.htm
Find more posts tagged with
Accepted answers
All comments
FormerMember
This file is
not
necessarily for adding a custom MIB. If your MIB is in our MIB database, you can add it that way.
If your MIB is not in the database, all you need to put into the wizard is the OID of your target MIB. You'll have to set all the parameters manually.
The import button does not import MIBs. It imports pollers. We will be adding the ability to export pollers, which will allow customers to share pollers.
The file that you're referring to was pulled from the release because it was not useful. Unfortunately, we did not pull it from the documentation.
From the release notes:
Missing XML File
The PredefinedCustomPollers.xml file does not ship with Orion NPM. The reference to importing this file will be removed in upcoming documentation.
Denny LeCompte
Sr. Product Manager, Orion
SolarWinds
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
