Hi.
How I can create a row "Total"?
I need show in report summ of values in columns.
Perfect. I recommend that you install the Orion standalone installer for Virtualization Manager (or leverage your NPM/SAM) to integrate with Virtualization Manager. You can then generate your reports using Orion web report
See video #8 Network Performance Monitor (NPM) Core Training - YouTube
There isn't really a way to do Totals in the spreadsheet reports that you export from Virtualization manager. You can however create Trends, and display them in widgets & export dashboards to pdf / save the trend chart as an image. All your reporting options are discussed below. The screenshots are for an older version but the process is roughly the same
Reporting in Virtualization Manager
assuming columns are integers:
select
c1,
c2,
column1+c2+c3...c(n) as rowTotal
From blahblahblah...
Where in Virtualization Manager I can run SQL queries ?
I didn't find it.
Which version of Virtualization Manager are you using?
Virtualization Manager v6.3.0.10011
