When you are editing a device settings via the 'Device Information' GUI, there is a 'Telnet' button at the bottom. This button is pretty much useless if you use SSH to connect to your devices.
Can you please replace 'Telnet' with 'Connect', so what when I user clicks 'Connect', it will start their telnet app if their method is Telnet, or their SSH app if their mehod is set to SSH?
I understand that everyone would have to insure their SSH client supports command line parameters, but overall this seems like a feature that can only help.
Thanks for your time!
