I just joined another company, and am to install the Orion on Virtual server.
I will need all support
Olamicash
+23408099444475
olamicash@yahoo.co.uk
olalekan.sobanke@etisalat.com.ng
Can you provide more information? What is the problem?
Good, no problem yet just desire to know that someone like you actually here with millions of others to work with.
I need to know what specification i need to put forward for the Orion i.e configuration on virtual server to work fine for my orion.
I will be getting the virtual server soonest and i will appreciate working with you on the installation and best practices, i am currently reading for my EXAM.
Same here. I have my Orion install split to 2 VM using VMware. each vm is running Server 2003 R2. Mine works fine as well.
just for future reference, don't post a thread titled HELP!!! unless you need help.
