Is it possible to filter what shows up in the "Last xx Config Changes" on the ORION Web Portal???
How???
you should be able to click on the edit button top right and there should be a section for filtering that is SQL based. not sure about the NCM piece, but can do that for typical Orion pages.
I have already tried that and there is no place for SQL queries???
See screenshot below,
hmmm, my bad. would have thought they'd have done that, but probably has to do with different DB and what not.
SW, any comments?
is it considered a report? maybe you could tweak the criteria that way...thinking out loud.
Sorry to resurrect an old thread, but I had the same question and wondered if there was ever a solution for this? I'd like to filter the "Last XX Config Changes" in views based on a custom property.
NCM 7.2/NPM 10.5
