Hi all
Currently in the proccess of setting up a solarwinds enviroment with full fail over capabilities.
So ill be having a duplicate set up of the primary sql, pollers and webbroswer in another Datacentre.
My question really is when adding devices into the active pollers in Data centre 1, Do i need to manually add the same devices to the pollers in Datacentre 2?? Or do i leave those pollers active and collecting data at the same time??
Also is VPN a viable method of the sql servers replicating their data across?
