Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
SOLAR WINDS ALERTS
strongbrave
SolarWinds send alerts out 2 alerts. One is a WARNING alert, the other is an UP ALERT. These alerts go out within 15 seconds of each other. Is this normal?
What can I do to test the validity of the alert?
Also, can I adjust the alert timing sequence.
Find more posts tagged with
Accepted answers
All comments
Isaac
Dear strongbrave
If you paid attention to your cousin strongmad you would know that we need a little more info in order to solve this here problem.
1. What version of SW are you running?
2. Are you using the canned alerts or your own creations?
3. What are you alerting on: nodes or interfaces?
It is likely that you have the alert event set to either warning or both warning and down. Warning events can be sketchy depending on your polling settings and the number of elements you are monitoring. I suggest changing the alert to down for the trigger and up for the reset conditions.
Be fantastic.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
