Hey folks, I was wondering if anyone else has problems with using sql queries to select devices in Orion NCM version 6.0 (although I had the same issues with earlier versions as well). I've pretty much given up on using sql queries.
I would like to be able to run a script against all our 2911 routers...about 100 of them. Unfortunately, if I build a simple query searching for all nodes with a node name that contains "2911" the console generally crashes and I have to exit the console and restart it. (I get weird diagonal lines across the screen with lots of popups talking about script failures). Today, I decided I was going to write down the failure and open a thread on it here at Thwack. Oddly enough, the query didn't crash. Instead it returned ONE of my 100 devices that contain "2911" in the node name. Not as bad as the console crashing, but STILL not very helpful.
I doubt the problem can be ME because building a simple query that selects all nodes where the node name contains "2911" is NOT rocket science.
Any suggestons, folks?
Dan Goodale - Network Engineer, Triwest Healthcare
