Is it possible to add yes/no custom fields to IPAM? This would be useful for marking IPs as covered by XYZ other system. ex. yes/no for ip is covered in npm or apm.
You could then easily run reports as to what ips are covered and which are not. A text field could be used but it seems like the custom fields should follow suit with the other Orion products and offer yes/no status for such things.
