Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
IMC Media Converters
Denis
Does anyone have IMC Networks media converters working with Orion? We use IMC iMcV 18 Chassis with iMcV-Master module w/RS232 (SNMP module) and iMcV-Lim media converters. We are able to ping the device with Orion but it does not pull down the MIB.
I contacted IMC and they said they support HP openview but did have a issue 6 month back with a customer who used their product (I believe there product was re-labelled to PrismaView) and it was a syntax issue where there was a discrepency in the RFC 1643 spec.
They are checking into it but don't think it is their product having the issue.
The problem happen after you enter the IP of interface and community string Orion just sits there waiting... it looks to be like it doesn't understand or can pull down the MIB.
Thanks, D
Denis
Find more posts tagged with
Accepted answers
All comments
Isaac
Hi Denis,
You may want to ask your vendor what MIB they are using. If it is a custom vendor MIB it is unlikely to work with Orion. Orion only looks at a fixed set of MIBs which include standard interface info and host resources (CPU, MEMORY, etc). In addition, they have some Cisco specific info thrown in (because Cisco is King Kong in the network world).
If you do a search on custom mib in the forum you will see a full accounting of this issue.
Be fantastic.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
