We recently moved a router from our "pal" site to our "pal2" site. As a result, the name of the router changed from "palrtr02" to "pal2rtr02". After the name change, I went in and "Rediscovered" the device and then changed its "node" name, however as of this writing the reverse DNS hasn't been updated.
A bit later I went to go search for this router and another one using the "Node Search" option. In doing so I noticed that the list, which is usually sorted correctly, now has "pal2rtr02" sorted incorrectly. Instead of having it with the other "pal2" devices, it has it in with the others. See the attached screenshot for example.
Its almost as if its displaying off the "node name", but sorting off the "reverse DNS" entry in the Node record?
Not a big deal, just odd...
