Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Engineer's Toolset
TFTP SERVER TIMEOUT
avideditor
Hi guys,
I'm having a problem downloadind the cisco config, My network adapter is set to 192.168.0.1 and the tftp serrver doesn't seems to work a this address, any tips ??
tks in advance
Find more posts tagged with
Accepted answers
All comments
Bryan
What sort of Subnet Mask are you using with that address? /24 or /16? Do you have more then one network adapter on the SolarWinds server? Sometime if you have more then one NIC on two seperate subnets, you will have to go under the prefs and select which address you want the TFTP server to use.
Lockheed Martin
Atlas V Launch Operations
Network Engineer
Network_Guru
Are you using the RW SNMP community string?
Do you have any SNMP ACL's set on your router?
Do you have an ACL set on the TFTP server?
Is the TFTP server set to both read and write?
-=Cheers=-
NG
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
