We are currently trialing Orion with all plugins and one of the most important of these is the Netflow plugin for us as we are baselining out network for VOIP. We want to be able to do QoS analysis /reports from our Netflow data ( if Soalrwinds captures this field ? ) so we can see if any of our many apps. are tagging packets with CoS/ ToS values that would utilise our EF / Gold queues on our WAN links. The VOIP QoS channel would be monitored hopefully by Netflow with possibly alerting in place aswell ? Is their anyway of configuring the Netflow plugin or from any other Cisco Netflow config parameters that will allow us to see the QoS values set for particular ports / applications ?
Many thanks in advance
NTA does capture the ToS field. If you're not seeing it, you can go to Admin > Manage Views and add the ToS resources to your views.
