Here is my scenario.
I run download task to stage the updates to each computer on a weekly basis.
On patch day I run an download/installation task with the option to reboot enabled (regardless of windows update status)
I checked the results and about 33% of the computers did not reboot as configured. I spot checked random servers with a powershell script to verify this, and they have not been rebooted since June. When I've tested this on smaller computer groups it works like a charm. Does anyone have any advice on what I should change to correct this issue? I've started to look at the various log files but since this happened on a large scale I figured it would be a more global setting or issue.
Any suggestions are appreciated!
