Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Goal Oriented AI
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Availability reports
KimWest
I am trying to put together a single report that will be placed in a folder accessible from the menu bar with the following information.
1. Time of last outage
2. Number of days up since last outage
3. History maximum # of days up
4. Monthly availability %
The web interface node detail page gives the last time the device was rebooted but not the last time it was unreachable. I can make or use the existing monthly availability report to get group or individual node percentage, but including the first three queries on the monthly availability report is my issue. This would be useful for Internet circuit availablity monitoring.
Has anyone constructed an SQL statment that was succussful in pulling the neccessary data for number 1, 2 and 3 above from the event table to get the up time based on events?
Kim West
Find more posts tagged with
Accepted answers
All comments
rossw
Kim,
Take a look at this post/thread.
www2.solarwinds.net/.../topic.asp
rossw
Kim,
Any luck?
Ross Warren
KimWest
I had sent you and email directly on this but I was also waiting for your reply on how it would work using report writer and not SQL manager to make the statement.
Kim West
rossw
Kim,
I haven’t been back to report writer to get the query to work. I will try to get it done this week.
Enterprise Manager should be on your local machine if you aren’t using remote database.
Here are some answers (kinda)
Sort of 2/3 (from resources in the forum)
SELECT TOP 25
StartTime.EventTime,
Nodes.Caption,
StartTime.Message,
DATEDIFF(Mi, StartTime.EventTime,
(SELECT TOP 1
EventTime
FROM Events AS Endtime
WHERE EndTime.EventTime > StartTime.EventTime AND EndTime.EventType = 5
AND EndTime.NetObjectType = 'N'
AND EndTime.NetworkNode = StartTime.NetworkNode
ORDER BY EndTime.EventTime)) AS OutageDurationInMinutes
FROM Events StartTime INNER JOIN Nodes ON StartTime.NetworkNode = Nodes.NodeID
WHERE (StartTime.EventType = 1) AND (StartTime.NetObjectType = 'N')
ORDER BY StartTime.EventTime DESC
#4 (From Other Sources in the Forum)
SELECT CONVERT(DateTime,
LTRIM(MONTH(DateTime)) + '/01/' + LTRIM(YEAR(DateTime)),
101) AS SummaryMonth,
Nodes.Caption AS NodeName,
AVG(ResponseTime.Availability) AS AVERAGE_of_Availability
FROM
Nodes INNER JOIN ResponseTime ON (Nodes.NodeID = ResponseTime.NodeID)
WHERE
( DateTime BETWEEN 38561 AND 38592 )
GROUP BY CONVERT(DateTime, LTRIM(MONTH(DateTime)) + '/01/' + LTRIM(YEAR(DateTime)), 101),
Nodes.Caption
ORDER BY SummaryMonth ASC, 3 DESC
Hope this helps.
Ross Warren
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
