Hello,
Are the reports somewhere in the Orion DB? I need the Maxbps_In95 column that comes standard out of the box for the previous month 95th percentile report. Thanks.
You can check in the corresponding component statistics details tables in DB.
have you tried the perfstack?
i do not see any table that lists that data
is that a column in the DB?
