What is max supported size of Orion DB.
Database size is a fucntion of SQL, Sql Express is limited to a 4 GB database. SQL Standard and above do not have that limitation.
My Orion database (NPM,APM,Netflow, and VoIP with 3000+ elements) is 17GB
JB
Please note that on Databases, they include "White Space" into the size, compacting the database will give you a more true result.
Will you please help us the decreasing DB size.
Regards,
Riyaz Khan.
I am getting some error while compacting DB.
Riyaz Khan
No. At this point you should open a support ticket. Something needs to be truncated within your db- usually the syslog or traps table has grown substantially large preventing the maintenance & compact from working.
Reducing your poller settings as well as creating syslog rules might help. Are you using any other modules?
