Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Change in Volume Index
alfordc
Does anyone know what a change in volume index means? It has happened a few times on the memory and virtual memory of one particular server but I cannot find out why.
Also, I have recently found out that Orion could monitor Volume errors. Does anyone know of what kind of errors (e.g. bad sectors on a Disk, memory errors) would make up a volume error?
Thanks in advance for your help,
Chris
Find more posts tagged with
Accepted answers
All comments
Isaac
Hi Chris,
The volume index change, particularly for memory and virtual memory, is nothing to be concenred about. This is simply a change in the SNMP index value for the volume in question. This can occur because of a multitude of factors related to the vendor SNMP implementation and conditions on a host (reboot, more memory added, etc...).
Orion monitors Allocation Errors for disk volumes. In order to add this chart to the volumes view you will have to select a custom volume chart from the resource list and then select the Allocation Errors chart type.
I hope this helps.
Be fantastic.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
