Someone could help me to create alerts for my UPS Delta, and created pollers for battery voltage and output and input.What I want is to create alerts for output voltages and input as I can do this.thanks
Since you have the OIDs, have you already created the UnDP pollers? If so, go ahead and create the alerts that you need for each statistic. If you have any trouble with the alert(s) not working properly, let us know.
I created UnDP pollers for this purpose. However, our UPS devices are APC brand which won't help in your case. You'll need to find the correct OIDs for the Delta brand of UPS. A quick Google search reveals that you might want to start looking under
1.3.6.1.4.1.2254
Good luck!
If I have the OID for each alarm I need your help to create the alarm for a poller.Example output voltage poller
best regards
