When polling a table and mapping the table data to interfaces in Orion - you'll usually have to manually deselect unmonitored interfaces from the table or you'll get a long list with their interfaces ID's.
It would be great if it was possible to ignore interfaces not monitored by Orion as these are usually unconfigured or not in use.
For instance:
