Just a view questions how to use solarwinds in a correct way:
- I want to remove old packages from solarwinds server to reclaim disk space.
Is it enough to select the packages under "Administration and Reporting"/"Software Publishing"/"All Packages" and delete them? - I want to clean up my WSUS Servers from formerly published packages
I decline old packages. But it seems that they are not removed by the cleanup wizzard. Do I have to expire them per hand additionally? - I want automate some of the following tasks:
- I have to download the update files (Flash player, Adobe Reader DC and so on) in browser (out of patchmanager - so I cannot automate using patchmanager)
- I have to mark all needed new packages under "Administration and Reporting"/"Software Publishing"/"All Packages", right click and select "Download Content"
- For every WSUS in our environment: I have to mark all needed new packages under "Administration and Reporting"/"Software Publishing"/"All Packages" again, right click, select "Publish Packages" and hope that all packages are published successfully.
- For every WSUS in our environment: I have to mark the all new packages under Update view: "Third party updates", right click, select approve and then select the computer groups where all updates have to be deployed. If there are groups with only some of the packages they have to be approved separately - on every new update.
Additionally, after clicking on "Administration and Reporting"/"Software Publishing"/"All Packages" I have to wait some minutes (around 3 to 5 min) until the Package list is shown.
Is there something I can do more better, more efficient?
