On licesing of NPM will count the APs as element or only the Aruba wireless controlers?
Only the controllers are counted for licensing, we do not charge for the thin AP's if discovered via the controller. If you add the thin AP's as ICMP only nodes, then you will be charged a license for each thin AP. Hopefully that makes sesne
Can you set the controller to send those via SNMP or Syslog to Orion?
