This seems to be an issue directly related to my PC. Others don't have this problem in my environment. Quite a few areas throughout SolarWinds won't show correctly for me, no matter what browser I'm using. Any suggestions? Below is an example.
Browser specific? What happens if you use Internet Explorer or Chrome?
Update your display adapter driver?
Happens in mulitple browers, IE, Chrome, and Firefox. I'll update the display drivers to see if that's it.
Bummer, all drivers are up to date, no updates for Windows. I'm at a loss...
It looks like you've narrowed it down and eliminated SolarWinds and the browser, so it's really down to the graphics card itself, the driver, or some interaction around those two.
For grins and giggles, try the following:
Are you running the native resolution for your display?
I am.
Oh this is fun, after a large number of refreshes everything is showing fine. I don't know the number of times I refreshed, it was a lot as I kept trying different browsers and then it was fine and is staying. Not a clue what is going on. When/If this problems happens again I'll try out what you suggested. Thanks!
Glad to hear it's fixed (for now, at least).
Could be a good excuse to put in a request for new kit!
