I have created two separate groups, under each group I have created a subnet, when I click in the first group subnet and then select the drop down add/remove columns I deselect certain columns. I then go to the second group subnet and i see those columns are also deselected there. Basically I want to see certain columns in the one group subnets and different columns in the other group subnets. How can I achieve this? I am using IPAM 3.0
