Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Cisco Memory showing incorrectly
mr_sad68
I am monitoring my cisco 2611 and I have 64MB of RAM in it. It shows 64mb when I actaully telnet into to it also.
Orion though, shows it only as 32mb. Is this a bug, or do I have something set incorrectly?
Find more posts tagged with
Accepted answers
All comments
colinpryke
We are also having this problem - although it only appears to be an issue with our 3640's. I have mailed Solarwinds tech support with Orion screen shots and the show ver outputs showing the differances. I have not heard anything back though, not even an acknowledgement. I have heard that there is a v7.0 due for immenent release, so perhaps this is fixed in that?
rvallefu
I see the same thing however, if you "sh mem" you will note that the total Processor Memory is the same as what Orion is reporting.
Paradigm Technology Partners
rv@ptpinc.net
Woodzy
Having the same issue with my 2611's as well. I think the memory is calcuated after the IOS loads. SW shows the same memory as the ios cmd 'sh process mem', and the 'sh ver' cmd displays the actual memory install. Not sure if upgrading the ios will help.
Does anyone have an answer?
Adam
Isaac
The mib that is read for total system mem and percent mem used accesses only the memory available after IOS load. In other words the true system memory available on your routers is the value provided when you issue a sh proc mem command.
sfiermon
Well, you should all purchase something else than Cisco. I've run into so many problems with their routers. Enterasys is much better!
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
