Experienced users,
I tried to psot this message earlier, but never saw it come through, so I apologize if this is a duplicate post.
I will be adding a secondary poller on my network soon. I will not use this post to go into the rationale behind the decision, but I do need a little advice.
What best practices approach should I use to determine how to load balance the network between the two pollers? I should add that we have NetFlow, wireless and will likely add APM soon. As I recall, all the modules must be installed on the primary poller (right?), so how does that effect my load balancing approach?
Anyone want to detail how they approached this issue?
