When looking at our own profiles and selecting our rank from the "nitro4x_header_rank_box" the Z-Order should be set to make the dropdown appear ABOVE the footer element as the menu is unusable at lower ranks.
Hi dtawater
Thank you for bringing this to our attention. This is definitely a bug and not our normal style option. We will get to work on fixing it and will keep you updated. Thanks again! It's greatly appreciated!
