I have a server with a large number ( >100) of watchdirectory services running that I need to monitor via SNMP. I can't seem to find this ability in SAM. Help?
There is a SAM component type specifically for monitoring windows service vis snmp
This is written for ipMonitor, and has the information you're looking for.
ipMonitor :: How to Monitor Windows Services Using the SNMP - QA Monitor
HolyGuacamole is correct. Try using this.
When I clicked on your link it said page not found. Is there an updated location?
Here are some online help links that may be helpful: SNMP monitor and Service Status — SNMP.
And here are some SolarWinds Success Center links:
We also have a SolarWinds Lab Bits video, Configuring the SAM Windows Service Component.
Thanks for the quick reply. Exactly what I was looking for.
