im getting desperated at the Moment...
I do a backup with the NCM every night and that works fine but i Need also to save the config to a other tftp sever so i tried to build a script for it.
Now im getting a Little bit helpless because the ssh script didnt resolv any variavle and for example when i used @filename the script copy the file to a file named @filename. I tried a lot of Things i found at the community but Nothing worked :-(
Maybee someone have a idea About my issue. What i want is
start a script over the schedule that
1. logs in over ssh
2. do a copy running-config tftp 1.2.3.4 to a filename that should be hostname.date
I tried About 100 scripts and Things but Nothing worked for me :-(
Br
Florian
