quote:Originally posted by chrkovYou will have to change the ViewID=56 to whatever number used to display the CPE page which you have created.Can someone tell me how I can find out what this number on my system would be. Sorry.. New to Orion and still figuring everything out.Thanks
quote:Originally posted by pblatzquote:Originally posted by chrkovYou will have to change the ViewID=56 to whatever number used to display the CPE page which you have created.Can someone tell me how I can find out what this number on my system would be. Sorry.. New to Orion and still figuring everything out.ThanksYou can also run a querry against the Views table in the DB. Don't remember the raw SQL. I have DB on a dedicated SQL server and working with our DBA have a read-only account I use with excel to view the data tables.Thanks,P. B.Success requires three bones--wishbone, backbone and funnybone. Kobi Yamada
Here is something that I include at the end of every Orion e-mail alert that gets sent out:
This allows you to quickly get to the problem device in Orion.I include this in all my Syslog alerts as well.
I include a similar link but with this syntax.
http://<Orion-server>/Orion/NetPerfMon/NodeDetails.aspx?NetObject=N:${NodeID}
For alerts that pertain to a specific interface, I use the link below which will go directly to the interface details view.
http://<Orion-server>/Orion/NetPerfMon/InterfaceDetails.aspx?netobject=I:${InterfaceID}
How have you customized Orion?
We started with solarwinds as our network monitoring system, however we now use it as our printer installation site, network monitoring, bandwidth monitoring, event alert, exchange alert, Rack diagram layout, report writer and much more.
We are using the map maker and its links to nodes more and more as they provide a real time view of the nodes and alow us to intergrate alerts into it as well as directing "everyone" orther than I.T to a installation link to install there pritners around the world whereever they travel.
We have intergrated user AD accounts and enabled the Everyone group, meaning that solarwinds isnt just a I.T tool, its a company wide tool.
