I have looked around the forums but haven't found this specific post so I though I would ask.
First off, I like the direction that NPM is moving toward. Great new features in 10.4. There can be improvements sure, but it's really starting to move in a direction that will help me out a lot.
Is there any plans for the NPM Network Topology to show the port channels and interfaces within them? Maybe instead of showing an individual link, show the Port-channel, then when you hover over the port-channel it shows all physical interfaces within the port-channel between the two devices?
This would be of great help instead of having to go to the equipment to use cdp neighbors. This would also save me a lot of time when using the ConnectNow feature within the Atlas.
We are primarily a Cisco shop using 1841, ASA, WLC, Nexus, 3750's and 2960's...
