Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
New features in "unsupported" section
Network_Guru
I just installed the Report Scheduler yesterday. It's quite slick.
You can now send scheduled report writer reports via e-mail.
Way to go Solarwinds and company!
They also have added MIBS for Cisco Nbar in the January MIB update release.
It won't do anything for Orion, but if you have Solarwinds EE, you should be able
to use the MIB grapher util to post the Nbar stats to a web page on Orion, as per
the following post as per RogSchmidt:
www2.solarwinds.net/.../topic.asp
There is also a new swalertaction.dll file which broke alerting when I replaced the existing file with this one. Forunately I just renamed the old file, so it was easy to recover. Does anyone know what this one does?
-=Cheers=-
NG
Find more posts tagged with
Accepted answers
All comments
vsreddy
I updated the MIB in Engineer. Then went to graph the OID for the CISCO-NBAR-PROTOCOL-DISCOVERY-MIB using name: cnpdallstats.
Unfortunately it came up and said that it was un unsupported OID. However, I can see at the CLI that it is showing on all interfaces I have been added nbar to.
any ideas? Sounds like a router command that might be missing? Could the firmware not be up to date to support the SNMP traps???
Thanks for your help.
Network_Guru
Have you gone through the following document?
www.cisco.com/.../products_configuration_guide_chapter09186a00800c75d0.html
You must have CEF enabled as well.
-=Cheers=-
NG
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
