I have found a procedure for backing up and restoring configs in the Firepass 1000 SSL VPN equipment. I was wondering.....If I run a serial cable to my Cirrus Config manager host....can I pull the config over the serial line instead of by IP?
Beginning in FirePass version 5.0, you can use the snapshot feature to create an image of the current system software and configuration. You can use this snapshot image, stored on the FirePass hard disk, to restore the system to a previous version or configuration.
Note: The snapshot feature is available only on FirePass systems that are shipped with version 5.0 or later. You cannot use the snapshot feature on FirePass systems that you have upgraded from versions 3.x or 4.x. If you attempt to use the snapshot feature on a system that was not shipped with version 5.0 or later, you will receive the following error message:
This functionality is not supported on this FirePass.
Creating a snapshot
To create a snapshot, perform the following steps:
- Connect a serial terminal to the FirePass controller, using a null-modem cable.
Note: Refer to the FirePass Getting Started Guide for serial port settings for your hardware platform.
- Start a serial terminal session.
A login prompt appears.
- Log in with the username maintenance.
Note: A password is not required, by default.
A screen of conditions of use appears.
- Press the Enter key or type y to agree to the conditions.
A screen of options appears.
- Select the Create/restore FirePass snapshot option, and press the Enter key.
- When prompted to restart the FirePass controller in recovery mode, press the Enter key or type y to restart.
The system will reboot.
After reboot, you should see the following banner on the serial terminal:
Welcome to the FirePass Snapshot Create/Restore Utility.
Please login as 'maintenance'.
firepass login:
- Select the Create FirePass snapshot option and press the Enter key.
A status screen is displayed while the snapshot is created.
- When the snapshot creation is complete, select the Exit and Reboot FirePass in normal mode option and press the Enter key.
FirePass will reboot into normal operating (non-maintenance) mode.
Restoring a snapshot
To restore a snapshot, perform the following steps:
- Connect a serial terminal to the FirePass controller.
- Press the Enter key or the y key to agree to the conditions, or the n key if you do not agree to the conditions.
A screen of conditions appears.
Note: In FirePass version 6.0 and later, a confirmation screen will appear.
- When prompted to restart the FirePass controller in recovery mode, type the Enter key or type y to restart
The system will reboot. After reboot, you should see the following banner on the serial terminal:
firepass login:
Press the Enter key or the y key to agree to the conditions.
- Select one of the following options:
- Revert FirePass to last working configuration snapshot
This option restores FirePass using the last snapshot you created.
- Revert FirePass to factory default snapshot
This option restores FirePass using a snapshot of the base operating system at the time the unit was shipped. This snapshot does not contain your configuration.
A status screen is displayed while the snapshot is restored.
- When the snapshot restoration is complete, select the Exit and Reboot FirePass in normal mode option.
