Can i attach the SWQL Query tool to Virtualization Manager?
If not, what is the process to get attached to the database for queries?
Hello,
yes starting with Virtualization Manager 6.0 provides a SWIS service to which you can connect using the SWQL Studio. However, be aware that since support for this was added mainly for purpose of integration with SAM and NPM it was tuned up for that specific purpose. This means that you may not be able to access all the data that you would like to this way.
Connecting to the Virtualization Manager is a little bit different from connecting to the Orion SWIS:
https://[VMan.IP.address.or.hostname]:443/swvm/services/InformationService
Following is the screenshot of the log in dialog:
Now I suppose that you have default Virtualization Manager installation which uses self signed certificate for the HTTPS port, if that is the case you will see another dialog informing you about certificate issue. When you see this dialog just hit Yes.
After that you should be able to see and query some of the Virtualization Manager entities:
Let me know if you have any questions.
Perfect will try it out when u make it back to my desk. Will let you know the results. Thanks for taking time to reply
Charles Russell
Sent from my iPhone
Please excuse the typos
I see alot of data that i wanted. Querying all the tables in your post function as expected. Thank you very much, it'll gets me to the next step of my endevour.
While exploring the data database info through SQL, i see alot of references about VMAN.OrionIntegration and i don't recall setting anything up of the sort in my VMAN configuration. Is this just prepatory stuff for coming changes?
And a final new question about the SWQL Studio tool. Anyway to close open tabs??? As i'm digging around exploring, i find tables i want to work with but the workspace gets cluterred with the 5 other tables i opened to find what my data of interest.
RE: VMan Orion integration - yes, version 6.0 added extensive integration features in Orion - if you have not turned them on, you are missing the all the good stuff! For more info on features and how to turn on the integration, please review:
As far as the SWQL question, Lukas can give you a better answer. Note that 6.0.1 was just released and has some improvements to the SWQL integration.
SolarWinds Virtualization Manager v6.0.1 Release Notes
Brian
I would like to have my integration engineer get familiar with this but I cannot get to even the login portion -I can get the WSDL here but not the connection dialog.
https://xxx.xxx.xxx.xxx:443/swvm/services/InformationService.wsdl
Should I pass this off to them or is there something I might be doing wrong?
Hello bluefunelemental,
you need to use SWQL Studio from Orion SDK to connect to Virtualization Manager SWIS Service. You can find the download links in theOrion SDK forum. It comes with several example scripts.
Lukas
Hey lukas.cerny when I follow those instructions with VMAN 6.1 I get an error (after the certificate error) about being unable to connect due to basic authentication. Have you been able to do this with VMAN 6.1? I'm using SWQL Studio version 1.9.137.0.
That's a fairly old version of SWQL Studio. Before you spend too much time investigating this, I would try updating to 1.9. You can get it from http://downloads.solarwinds.com/solarwinds/Release/Orion/OrionSDK-1.9.zip. On the other hand, Lukas may already know what's going on here.
Never mind, carry on!
Oh man, typing fail. Sorry, updated the version to correctly state 1.9.137.0. I am running the latest/greatest.
Hi, are you sure you are using correct username and password? Because this error shows up when VMan is unable to authenticate the account. If you are trying to log in using domain account I'd recommend to try VMan account instead, or you can try to create a new user account and use it for connection.
That was the trick Lukas! The local admin account that I use to log into the web console (not the individual appliances for administration via the :5480 page) worked like a champ. Domain account definitely did not work though.
