I've upgraded to v9.1 but in the website the details of the pollers is v9 sp2 which is the version I upgraded from. I've checked in system manager and both pollers show v9.1. Is this correct?
That's strange. Could you post a screenshot of where it is showing v9 sp2?
I see what's going on. The "Service Pack" line right below "Operating System" actually refers to the Windows SP level, not the Orion SP level. And the "Package" line is referring specifically to the display name of the SolarWinds license key installed on that server. We only normally only change the license keys for major version increments, so 9.1 uses the same keys as 9.0. That's why when you upgrade from 9.0 to 9.1 you won't get the license dialog again. So I think everything's fine.
Is it too much to start actually putting the version name on the package line?
Instead of Orion NPM Polling Engine v9 SLX why can't you have Orion NPM Polling Engine v9 SLX SP2 or Orion NPM Polling Engine v9.1 SLX?
BB
