I have built a clustered SQL application monitor, it is quite small with only two nodes added (I have added the clusters IP address, rather than the two nodes themselves.) They share, like probably all clustered environments, the drives and the services.
I would like to monitor the drive(s) so that if the cluster ever fails and the drive swaps over, I can have a notification to know where the drive is.
I was playing around with the drive and couldn't find a way to resolve this. As a small fix, I added the drive to both nodes and tried to come up with a work around.
I have been thinking that as the cluster is being monitored, shouldn't it be true that EVERYTHING is monitored within that cluster? If that is the case, why, when I failover to the passive node, did my cluster display that the two shared drives were down? This is the reasoning for me adding both drives to each node.
Also, with regards to the alerts. I have been trying to set an alert up. I don't care if the drive swaps over, only that I know that the drive swaps over. I was playing around with alerts yesterday and trying to get my alert to work, but I couldn't.
I was monitoring the drives themselves and looking for any state changes. Again, I don't care if the drive moves from one node to the other, just that if the node moves, then I need to know about it.
Is there.
I hope someone can assist me.
