Is it possible to create a reusable custom alert action? I am setting up alerts to send information to PagerDuty so I have a couple of actions that need to be performed as trigger actions and another that needs to be performed as a reset action and they are always the same (or really similar) but right now the only way I can do this is to take the type of action ("Log the alert to a file" and "Execute an external VBscript") and add all the custom info into it which is a lot of cutting and pasting for every alert. I was hoping for a way to add the actions to the add action menu so I can just select them without having to do the configuration every time.
Is this possible?
-Jim
